beav350
- Lapeenranta, Finland via CA, USA
I am SURE that your starter is the problem. Although I cannot think of any previous scenario where this was an issue, the only thing that could trigger the CPS inadvertently would be if the starter solenoid was shorting out through it's case ground & triggering the CPS, which obviously is what is happening based on your starter pinion speed/spark speed. You removed the starter to replace the flywheel, did the plastic case of the solenoid crack? Check it, replace if neccasary, or try to borrow one for an A/B test. This is the only thing I can think of...
