Throttle
- A tree fort
Can anyone tell me what RPM stock Cherokee's run while doin 60(100km/hr)mph?
Throttle said:Can anyone tell me what RPM stock Cherokee's run while doin 60(100km/hr)mph?
techno1154 said:Ecomike,
It sounds you have a torque converter slipping or it unlocks going up a hill. 2,400 RPM at 60 MPH for you verses 2,400 RPM at 75 MPH for me. The looses going up over passes are neglegible even in 4th and over drive. I do not think tire size alone could make that much difference.
IA Green 96 is correct. More info would be helpful. At least the engine and transmission type would be helpfull even if we are just compearing stock to stock XJ's.
Uhhh, 4th is overdrive in the AW4, ?? It's pretty obvious in mine when the TC unlocks. I rechecked mine today, doing about 80 Houston overpasses, which may be steeper than your use to? On a flat stretch I am at 2250 rpm in 4th doing 60 mph, and 2400 rpm at 65 mph, and 2550 rpm at 70 mph. It also hits about 2,400 rpm at 60 going up an overpass if I want to hold 60 going up the overpass. If I push pass 2,400 rpm it would take about 1/2 WOT and would unlock the TC. I can't get past 2,400 rpm with out unlocking the TC when I am doing 60 mph.techno1154 said:Ecomike,
Saudade said:My stocker also runs around 2k@60 and 2400@75. My speeds are pretty accurate as I've verified them with GPS.
FYI: Mine's a 2wd, D35 with LSD, AW4.
