How important it is depends on year and options. If you have a late model without cruise, it keeps the heater from defaulting to defrost when you accelerate. If you have cruise in any year, it won't work properly without a vacuum reservoir. If you have an older model with a vacuum disconnect front axle, a leaky/broken/absent reservoir (or lines to it) will cause it to pop out of 4WD under load.
