92westshady
- Newark, DE
UPDATE: Thanks for all the advice guys. I couldn't tell where the leak was coming from but a couple of weeks ago I did the filter housing seals and the main leak seems to be gone. I still have some oil moisture back there but no dips and not enough to make doign the main seal worthwhile at this time.
Getting out the torx bolt is a pain. I had to remove one motor mount bolt and I used a set of low clearance socket adapters with hex heads.
