you can but you need (1) a tapered insert for each end, (2) remove or replace the swaybar mount on the axle to get them out of the way, and (3) 16" or larger rims to clear the joint
This insert... how does it work and what does it do? if the hole on the knuckle goes right through whats the needs for the insert? the only way i could see this being necessary is if the hole is tapered... and the inset reverses the taper... but that would involve drilling out the hole, correct?
