warm heater?
even with a cell for pics, you can see the upper half of the stock core is fairly clear, but the lower half is hopelessly clogged up - this is after rinsing the core and finally replacing it
also explains the low output, just can't circulate coolant
pretty fine tubing, the replacement had larger diameter tubes and coarser fins
(clickable thumbs)
(clickable thumbs)
