I cant believe you guys lost "The burping thread". I havent been gone that long, and things disappear.
burping the renix-(its been listed above, heres my version)
Jack the rear end up so the engine valve cover is high in the rear-
unscrew, but DO NOT remove the temp sender- leave it on but loose-
leave the cap on the plastic bottle on for now. it needs the pressure to work.
start engine- let it run, and when the thermostat opens, the air is forced out of the senders hole- through the threads(if you took it off, it will gyser-engoy the antifreeze bath, if you left it on just a few threads, the sender will be somewhere in the front of the vehicle when it shoots out like a missle-hopefully mising your head). When the air is out, theres plenty of force behind it, and the antifreeze will creep out(or spew)- hand tighten it back, shut off engine, count fingers and make sure their all there. retighten the sender.
let jeep cool for a minute, then carefully remove the bottle cap- restart engine and let the fluid spit and jump- its equalizing. turn off engine, refill bottle. Enjoy heat. repeat as necessary.
The heater bypass valve on renix systems is a lie- but, they do stick- check them by manually forceing the valve over- if it moves, its probably working. its a vac system- designed by deranged elves on crack paid by bendix corp- if its not leaking, it will soon enough. The french were good at something- Vacuum systems (they DO suck after all)
If the temp gauge is jumping, its air stuck in the top end- remove by burping-
if the guage is low consistantly, its usually a stuck open thermostat(or backwards-if you can find one that fits backwards)-
if its high all the time, the thermostat is stuck closed, or the engine IS actually overheating.
Its that simple.
