gr8Tyres
- Charlotte, NC
It's hard finding a strong one for my 89 XJ Wagoneer. Will later years XJs work? If so, which years, and do you have a good one near Charlotte, NC?atriot:
It have two small tears at the edges . The one at the front over the mirror where it is narrows to allow for the overhead console is the most critical. I would also like to stiffen it a little but not too much so as to make it difficult to replace.
I am thinking of using a piece of tape sealed in place with resin then seal the back /top section with a coat of resin. A coat on the under side may not be a bad idea either while hoping it do not become too stiff. I am also entertaining the idea of insulating the underside of the roof.
I will be taking the unit to an upholstery shop to have it covered.
Planning on doing the Same w/ mine. 1/2 to 1 Gal. Epoxy Resin on the Bottom Side. Applied w/ Roller & Brush.I would also like to stiffen it a little but not too much so as to make it difficult to replace.
Thanx Patrick.
Looked at Their Site & It's $45 for a 10ft Roll.
Also Like the fact that they're located Here in Texas.
US58
