If you have a wiper motor that no longer works, check the fuse/relay first. If that is ok, and you feel it necessary to replace the motor, it is a simple job. Wiper arms, cowl grill, hardware, and pay attention to how you have to rotate the assembly to get it out because you will need to remember that when putting it back in. The wiper arms that are under the cowl are going to come out with the motor as an assembly. Put it on a workbench and swap over the motors. Re-install is the opposite as the removal. The whole job, including getting a second beer, takes about an hour. Good luck!
Your instructions for the unrelated fix is super good for those who have never been there, done that, etc. Quite concise to help, keep up the good input as it is good to give out info that can give one the confidence to take the plunge.:clap:
HOWEVER.., that post of mine was a simple April Fool's Joke, i.e., notice the sentences are typed mostly in small case, but in large case are the capital letters that spell out; 'April Fools'. (Got'cha).:wave:
MODERATORS; As a paying member; I request that this post of mine be taken down by 04/07//17 so as to prevent further issues.arty:
