PowerRam1987
- Warwick, RI
hey guys so i have come up on 210k miles in the 96 XJ and some preventative maintenance things are in order. i've owned it for a year and have no factual info about how well it was maintained or about previous owner. drove this thing straight out of the junkyard i work at. only needed a radiator and floors-it had quite a few new parts and fuel/brake lines so i assume someone was trying to maintain it lol
BACK TO THE TITLE so i want to do a head gasket and while i'm at it do some little stuff here and there for minor performance but keep my stock internals (not building a stroker yet haha)
i'm just going to buy another 96 head to build ahead of time
-open up the intake and exhaust ports
-match them to the manifolds
-deck the head .010 (i've read a lot of people take that much off-could i take more off for my stock application?)
-get a nice gasket between .040/.043 thickness (should be plenty of wiggle room with factory components)
-new studs/bolts
-new timing chain
-new water pump
-get rid of the clutch fan while i'm in there
-possibly 63mm throttle body
SO i'm looking for suggestions on or part #s for:
-some stock size valves OEM or better quality
-stronger valve springs factory fit
-who in the experience of the stroker guys makes a nice head gasket for 4.0s
-what hardware are you running? ARP, just grade 8 stuff, other name brands?
-is the MP double roller timing chain a good idea or is there something better?
-like i said earlier could i take more than .010 off the head or would there be not much more benefit?
motor is otherwise stock with a CAI, TB spacer, good flowing 2.5" exhaust
THANKS IN ADVANCE
-new studs/bolts
-new timing chain
-new water pump
THANKS IN ADVANCE
