- San Diego
like ivan said, the head of the bolt may be the only thing off center, even then its only part of the bolt head. and with it being so close to the center of the rotating mass, i doubt it will cause any long term harm of any kind.
Ben, I understand how it works. But that bolt is like a wheel weight; it has mass and would be eccentrically spinning. I'm not suggesting getting the bolt off center would put the yoke off center....come on.:looney:
how does the front shaft go for length when used in the rear, i have 4 inch lift and a 8.25
does it have to be lengthened or is there enough movement between the two halves
my understanding is that once the hack and tap is done the diff yoke has to be pointed at the out put shaft using wedges, is this correct??
does anyone know what the measurement is on the dirt bound hnt kit is?
