mbklmann
- beaverton, oregon
60/9 9 inch center section with 60 outers.
Step up.
Step up.
mbklmann said:60/9 9 inch center section with 60 outers.
Step up.
cal said:The last rumor I heard, cracker had a rear high pinion 60 with disc brakes, a detroit and 5.13's for sale...
IXNAYXJ said:I would seriously think about the 8.8 with Super 88 kit. I've beat the ever loving crap out of mine, and I broke my HP D44 first. I'm running alloy shafts and I've never had an issue, even with out the Super kit.
A buddy of mine is running the same set up on 35x13.50 Krawlers and also wails on his...he's never broken a 8.8 component at all. I'd say 37" Trxus (what I'm running, but 35's) weigh about as much as 35" Krawlers.
As to other issues you mention, I cannot make my HP D44 clear my TnT LA's. No matter what I try, they still keep hitting the LA's. I'm down three yokes and joints in the front shaft. Just be aware.
I'd think (with an automatic) that 5.13's would be plenty for what you're describing.
-----Matt-----
Gaius said:Bulletproof with 37s? Doesn't matter, your front's not going to be.
How much do you want to spend?
A low pinion 9 is a good, cheap option, but the pinion is the lowest of all LP options.
A 60 or 70 would be great, but not sure where to get one that's already 63ish inches wide.
I would go 14 bolt with Dually hubs. It's 63 inches with no modification to the housing or shafts, and can handle 40s with ease. Problem is clearance. You can shave the housing and ring gear to get more clearance than a 60, but that takes work and money. Gear setup is WAY easier than Dana axles, the pinion is higher than the 9inch and Dana offerings, the Detroit is cheaper (lunchbox type), and you can get them for $100.00 at any junk yard on the planet. I got my SRW 14 bolt (67 inches) for $40.00.
ZachMan said:Okay, finally hoping to go to the next phase next year on my Jeep. I have a few questions about my build I'd just like some advice on.
1. I will be running a 64"ish wide HP d44 that will be loaded out, high-steer, chromo everything, OX locker, .500 wall tubes, etc.. My question is whats a good matching rear axle? I was thinking of building an 8.8 with the "super 88" kit and spacers, but now I am leaning towards a d60 or d70u rear axle....just clearance will suffer.
2. I run RE 4.5" (w/ front spacer) and 33s, I plan to just run RE stuff again just taller with TNT LA kit. I am thinking 5.5" coils and my 3/4" spacer (or 7.5" coils and no spacer) and 4.5" leafs with TNT 1" taller u-bolt elims and RE shackle. How much lift are YOU running with 36/37s? I hope to push the front axle forward 3/4" - 1" also and the rear 1" back. I am trimmed with no rear lower 1/4 panels.
3. Do I need to go 5.13s or 5.38s with 37" radials? This Jeep will see every type of driving there is, stop and go, 75 mph hwy and of course trails. I will be wheeling 3 weekends out of 4 a month. I can say 4.56s and small 33s feels great for a DD, while 4.56s and 35s seemed low on grunt for me. I have no issues running 2800 rpms or so at 70mph.
4. Do I need hydro-assist with 37s and being a driver? PSC? redneck?
5. With running true high-steer does anything interfere with the steering besides needing an ontop the axle straight tracbar? swaybar maybe? need to change the pitman arm? I was thinking lift might need to be determind from this too.
I misspoke on this. The Dana 60/70 does have the highest (low) pinion, at 1.5 inches below centerline. I went out and measured my 14B at about 2.5 below. It does, however, have the shortest pinion, but that only helps the short wheel base guys.Goatman said:BTW, a D60 has the highest pinion of low pinion axles, and it also has the lowest pinion of HP axles. If you can get someone to shave a LP 60 for you, and narrow the tubes, you can build a shaved LP60 pretty cheap, or even buy a Currie Iron jock.
Gaius said:I misspoke on this. The Dana 60/70 does have the highest (low) pinion, at 1.5 inches below centerline. I went out and measured my 14B at about 2.5 below. It does, however, have the shortest pinion, but that only helps the short wheel base guys.
The beauty of the 14 bolt and D70 is the beefcake axle for the cheap price. If you are really building nice axle, and have the money to do so, I would get a Solid or Currie HP60.
That is a weakness, but one that is easily remidied by welding the tubes. Mine isn't even trussed and it's fine after four seasons.Goatman said:If you like the Super 8.8, it should hold up, just be sure to truss it and weld the tubes.
Goatman said:You haven't said what terrain you're mainly running, but I assume mud, which isn't as hard on parts as rocks are. You also haven't said what your budget is. Plenty of guys are running 37's on front D44's and as long as they're careful they can last......but they are subject to break. Personally, I've never broken anything on my rig as much as I've broken my HP44 front axle after I went to 37's, but that's all hard wheeling in the rocks.
I think the Super 8.8 isn't a bad idea for the rear. A junk yard D60 will have 30 spline axles and I've seen them break with 37's. If you wanted a 35 spline D60, I'm sure you could build a LP60 for as much as it would cost to build a Super 8.8. I'm with you, the 9" pinion is just too low.......who cares about anything else. I also wouldn't bother with a D44. Sure, it could last awhile, but you'd always be worried about breaking an axle or a ring and pinion. I've seen LP rear D44's break gears (I did with 33's), and I've seen plenty of 30 spline shafts break with 36's and 37's. Since you're building something, I just don't see a D44 as much of an option for 37's. If you like the Super 8.8, it should hold up, just be sure to truss it and weld the tubes. BTW, a D60 has the highest pinion of low pinion axles, and it also has the lowest pinion of HP axles. If you can get someone to shave a LP 60 for you, and narrow the tubes, you can build a shaved LP60 pretty cheap, or even buy a Currie Iron jock.
I run 37's with a lot of trimming and 7.5" of lift, with quite a bit of uptravel. For a full bodied rig I think that is ideal for 37's, wouldn't want it any taller, and you'd have to limit travel or really cut it to be any lower.
Yes, you need at least 5.13's to run 37's, and I agree that you might like the 5.38's better if that is an option with whatever rear end you choose. (how low can you go with an 8.8?) Like you, I ran 4.56's with 33's and it was fine, but I went to 5.13's with 35's, then went to 37's. My 170k Renix motor struggled with the 37's and 5.13's, but then I did a stroker and it pulls it very well.
You'll be happier with hydro assist. If you get an 808 gear box, the bigger bore box, and a real good pump, it will be OK if you know how to keep the stress off the steering by moving slightly, loading the torque converter and keeping the idle up, rocking by modulating the pedal with an automatic, etc. But, the assist works as a very good stabilizer/cushion to the steerng and can help to keep from breaking steering parts.
Nothing special with the high steer arms, other than getting the steering link angles correct and making sure everything clears. Yes, the track bar needs to be high, also. A sway bar is dependent on how your rig handles. With stiffer coils and good shocks it can be OK, but nothing wrong with running a sway bar with the amount of lift you'll likely need.
Good luck with both your health and your build. :cheers:
Check out my issues with the set-up...and lack of resolution:ZachMan said:Crap, so you don't clear a HP d44? I was/am sure there are others running the same setup okay...but I am thinking it took modifications. Hmmm, I might have to ask TNT about this I really don't want to run a different kit and I have had the TNT kit in my garage for forever sitting.
Goatman said:The list is growing of guys who built front D44's or 9" with 44 outers, and are now building front D60's or 60/9's. If you're running what you say, look seriously at just doing a front 60 from the start. Really, 37's are fine on an XJ, and you don't need chromo shafts and CTM joints with 37's. You'd have a hell of a time breaking alloy 1541 shafts and Spicer D60 joints with 37's, it most likely would never happen, so that could cut the cost down some.
Goatman said:Really, 37's are fine on an XJ, and you don't need chromo shafts and CTM joints with 37's. You'd have a hell of a time breaking alloy 1541 shafts and Spicer D60 joints with 37's, it most likely would never happen.
IXNAYXJ said:Check out my issues with the set-up...and lack of resolution:
http://www.naxja.org/forum/showthread.php?t=926319
-----Matt-----
