Gaius
- Beaverton, OR
I bought a front AAM 9.25 for 400.00 locally. Just need to have it shortened.
Here's my post from a local board:
I picked up my front axle for my upcoming build - an AAM 9.25 axle out of a 2005 Dodge 2500 CTD. It has 20k miles on it.
Specs:
Ring Gear Diameter: 9.25
Ring Gear Bolts: 12
Cover Bolts: 12
Carrier Breaks: none
Spline Count: 33
Float: Front
Semi-Float Type:
Pinion Support: False
Axle Lugs: 8
Models:
1 Ton Dodge Pickup: 2002 - 2005 (Front)
3/4 Ton Dodge Pickup: 2003 - 2006 (Front)
~ 71inches WMS to WMS
high pinion drivers drop
Ball joint knuckle, large hub bearing
3.73, 4.10, and 4.56s available from the factory
Can use GM gears up to 5.38s with a ring gear spacer
Available electric locker from the factory
ARB and Eaton E-locker is available
1485 series u-joint (Dana 60 is 1480)
33 spline 1.4 inch inner and outer axle shafts
Sorry about the bad pics. I'll update this post with better as I build it.
Also here's my rear:
And my wheels I got the other night.
Specs:
Ring Gear Bolts: 12
Cover Bolts: 12
Spline Count: 33
Float: Front
Semi-Float Type:
Axle Lugs: 8
Models:
