ghettocruiser
- Norristown, PA
ricot83: I dont have pics of how it bolts up... but it uses the two bolts for the sway bar brackets. Also, it uses a 1/2" hole towards the front. You have to drill this hole and use the supplied carrige bolt and washer. It is tons easier to remove the front bumper and do this, but its possible to do without removing it.
As far as side pulls, it should hold up good...even better than hooks. WIth a side pull, all the force is on just that one hook/bracket. With a hitch, the force should be spread out more since its all tied together...both sides of the hitch, and both "frame rails". I really dont see it giving way unless you are in a really hairy spot with someone yanking the crap out of your front end.
Justin
Justin
