Going to electric fans from U-Pull-It.....what to look in? and what else to look for?
Just what it says. What vehicle is a direct bolt up to 96 XJ Auto. Want to remove the engine fan and replace with electric. TIA Jeff CamoXJ
I was also going to replace the stock one because it was howling when turned on because of the pond but broke into the case (which isnt easy) and cleaned everything and reinstalled and works like a charm.
What other stuff can I look for at the U-Pull-It yard? Stuff that is direct bolt up that is an upgrade? Anything................
