I haven't done much on this never ending project until just recently, so here's an update and a bunch of pictures. This sub project was to build a shroud and fan mount for the radiator. First, I attempted to build a cardboard template for a radiator shroud.
Bent up it looked like this:
I designed it to mount a cut down Ford Taurus fan in the lower drivers side region. Here it is transferred to a piece of aluminum sheet:
Here it is bent up on a friends 3 in 1 Enco bender/shear/roller. I also cut out the hole for the fan leaving several tabs to be bent up for attaching the fan to the shroud:
Here the fan is sitting on the shroud.
Here is the fan in place with the tabs bent up. BTW, I kept a little metal lip between the bent up tabs for the fan housing to sit in.
This photo shows the overal look from underneath.
This shows a half inch clearance between the fan blade and a line across the shroud (where the radiator cooling fins with be.)
For those sharp eyed readers, one can see a spot or two where I screwed up on the actual aluminum sheet. Oh well, I'll just have to fill the screwed up gaps with a piece welded in since I was going to get the corners welded anyway!
I'll show it mounted in the project in the next post. Jeff
