Probably not, as the gaugeless cluster uses a different speedometer with no trip odo. I can't remember now, but I seem to recall that when I did my 95 it would not fit anyway.Note: You can probably swap the speedometer from your existing cluster into the new cluster; this will keep the mileage units correct as per the law.
At least on my 1990, there's a tiny c-clip on the odometer shaft. Pull it out, and you can separate the individual 'digits' on the odometer and spin them freely by hand. Then just press them back together and insert the c-clip again, and you're good to go.Probably not, as the gaugeless cluster uses a different speedometer with no trip odo. I can't remember now, but I seem to recall that when I did my 95 it would not fit anyway.
