Well, a lot has happened in the last six months that I neglected to mention. The 1986 MJ with the Chevy 2.8L V6 took a turn for the worst and lost compression in one of the cylinders. Pulled the engine and tore it apart and found some very interesting things. Decided it wasn't worth the money to rebuild it, so I sold it to a guy down the street who has a use for it and plans on dropping in a rebuilt engine.
The 1990 MJ had the gas mixing with oil problem, but it wasn't nearly as bad as the 1988 MJ I bought six months ago. There was definitely a little bit of gas present in the oil whenever I changed it and I also got 6 3/4 quarts out of the engine whenever I changed it so somehow the engine is producing oil rather than burning it
But in all seriousness, it was definitely gasoline in the oil - you could just tell by the smell and how much thinner it was. Anyway, I sold the 1990 MJ too and notified the buyer of the problem, but he didn't seem to mind too much as long as the oil pressure was within spec (it was) and the engine still ran fine (it did). He was just using it as a work truck around his ranch so he wasn't overly concerned with the problem, plus the price was right
Now, with all of that said, I was left with just one 1988 MJ. This one had the gas mixing with oil problem BAD. I'm talking 8-10 quarts drain out on oil changes and I have to change the oil every 100 miles or so. It comes out super thin and it smells very bad. I'm having the injectors cleaned as we speak, and hoping it solves the problem...only time will tell.
Since I only had one MJ and I'm not used to only having one, I went out in search of another and came across a 1988 MJ w/77K. Full details on that truck can be found here:
http://www.naxja.org/forum/showthread.php?t=902646 This truck has a similar problem to the 1990 MJ I had. There is a slight mixing of gas and oil in the crankcase, but nothing bad that it's dropping oil pressue or making the car run like crap. If the injector cleaning service solves the problem for my one 1988, I'll be cleaning the injectors in this truck too.
I'll keep you all informed.
