rickolis22 said:so this whole resetting the pcm thing. i have a 94 xj. so what i do is take off the positive battery cable. then what. do i just touch the positive battery cable while it is disconnected. i'm confused about grounding it. can i touch the positive cable to some part of the jeep while it disconnected from the battery? let me know so i don't kill myself please.
Ecomike said:Be sure you know or mark where each cable goes back on the battery, i.e. which one goes where before you remove both cables from the battery!
Some of us are worried about nobs pulling just one of many cables off the battery post and getting a shocking experience, or worse some inexperienced having more than one battery in the system they decide to short out...etc.srimes said:Why would it matter what cable you removed? Just remove one from the battery and touch it to the other that's still connected to the battery terminal. Remove positive or negative and touch it to the other, doesn't matter which. But just in case you overlooked something do it slowly and be ready to jerk it away if there's a big spark.
Ecomike said:The easiest way to keep it straight is to disconect both battery cables from the battery. Then short the two DETACHED battery cables together.
Blaine B. said:That's what I was thinking. You can't really screw that up by removing all of the cables from the battery!
