Garage stuff!
FloydXJ
Salt Lake City
I want to take some crap to the dump next weekend, but can't help but think someone somewhere might want some of it. So please let me know if you want any of this!
Stuff that is getting tossed....FREE!!!!!
Open D44 carrier, ring, and pinion - 3.54 ratio.
2.72 front half of an NP231 from a 99 XJ. No idea why someone would actually want this (because you have a cracked case? Broken output shaft?)
CV driveshaft from the front of an old FSJ. About 25.5" from outer joint to outer joint compressed.
XJ rear driveshaft, slip yoke style. A little longer than average, so may have been off a manual. About 29" joint to joint.
Stock XJ spare tire donut with the hookie thingy and greay carpet. Useless to me for many reasons...:looney:
Black shock boots x2 - never used, still in package.
Brake light housings! Driver is beat up - scuffed and missing a small chunk on the side, and also the bottom mount is broken off. BUT, would still pass safety! The passenger has some very light scuffs.
Axle shafts - D44 stock. Two short inners and one long inner for a PASSENGER diff axle (not interchangeable with Driver diff axles), 30 spline. One 19 spline outer that of course is the same most Jeep D44s.
Knuckles - off '85 FSJ, D44. Not flat tops. Ball joints are old. Not toast, but old.
Again, that stuff is all FREE!!
Stuff that is not free:
D44 high steer arms. I do not recall for sure where these came from - I think Polyperformance or Partsmike...but they are not used. I ended up going another way before install. $100
D44 knuckles from currie. These are flat tops with studs and conical washers for full high steer (and of course would work with the above arms). Ball joints and knuckle are new. I was going to use this for mine, but couldn't. The tie rod was going to be too close to the everything to clear, and these do not have a front arm for a stock location tie rod. $100
Clayton 6.5" coils. $75
Clayton super duper far dropping pitman arm that comes with the 4.5" and higher lifts. Not sure how far below stock these drop, but it is about 6" from the bottom of the sector shaft hole to the center of the DL hole. $20
Clayton track bar. Bushing is questionable - the bolt that is in the axle end appears to be seized in the bushing and was cut out. If you can get the bold out, the bushing may be useable. The other end is a 2" Johnny joint and was not toast, but is old. The hole to hole measurement is currently 32.5" and it is adjusted mostly out (long). It is bent to fit in the stock location on the axle end. $10
I have pics available if there is interest in any of these. Please post up if you would like pics of an item. Post here, PM, call!
Done - PM me with when/where you want to grab them. Toby - do you have a passenger diff D44 the inner shafts will be useful on?
I'll take the coils if you still have them when I get back from work on the 9th.
Still got them - you officially have dibs. :greensmok
I have dibs from others on the driveshafts, pitman arm, and NP231 front half, all the D44 shafts, and some interest in the new knuckles. Everything else still up for grabs.
Can posts be edited this long after the fact so I can note that in the first post? Not seeing an edit button up there. :compwork:
Bump for my grade A junk!
Driveshafts are gone, and there are dibs on the axle shafts, coils, 231 front, and possibly the Currie knuckles.
Everything else is still up for grabs! Save the free stuff from the garbage!:eeks1:
Still got the passenger side brake light housing? I'll take it if you do. Mine's an '01. Same part?
If anyone is looking, the driveshafts are gone. Passenger light housing, coils, and drop pitman have pending pickups. All other items still up for grabs!
