TrueBlueXJ
- Almost Heaven, West Virginia
Specs: '96 w/ RE 3.5" SF, 31x10.50 TrXus MTs, AX-15 trans? (2.5L 5-speed).
I hear alot about "vibes," and I'm guessing this is one. I don't feel it, I just hear it. It shows up around 65mph but not when my foot's on the gas, only when I let off. It's started showing up at lower speeds (55-ish) when I'm in fourth gear, but again, only on release of the pedal. And I can hear it when I'm rolling in fourth gear and I press on the clutch. Front driveshaft? Transmission? Sounds like it's coming from somewhere under the shift stick. I'm leaning toward front driveshaft.
T-case drop? (sitting in the garage)
SYE? (can't afford it)
