- Rainy side of Washington
OK, I got the hardware needed to put a second 4.0 HO temp sensor into one of the tranny lines today. Got a couple questions for 4.0L/engine gurus:
* what's the temp at which the engine computer goes to normal mode instead of lean mode?
* what type of sealant should I use on brass fittings exposed to tranny fluid? I'm assuming standard plumber's pipe dope would be a bad idea, how about teflon tape? Anything else I can use? These are NPT thread and are definitely going to require some sort of sealant.
My intent is to install a pushbutton inside the gauge cluster next to the temp display that will toggle back and forth between tranny temp and coolant temp by switching the temp sensors in the thermostat housing and the tranny line using a relay. This should be compatible with any year except the dual temp sensor years (which are even easier to do this with, no worrying about lean/rich mode) as long as you only switch to the tranny sensor after the transmission fluid has gone above the lean/rich switchover temp - unless anyone sees a problem with this, in which case tell me!
For those interested, the current BOM is:
* 2x Watts A160 3/8 flare nuts
* 2x Watts A183 3/8 flare to 3/8 NPT fittings
* 1x Watts A758 3/8 NPT tee
* 1x coolant temp sensor from junkyard (clean coolant residue off)
* 1x relay + assorted electronics to switch it however you want (I'm going with a 7805 5 volt regulator, some capacitors, a 74LS76 flipflop with JK pulled high, a driver MOSFET, and two LEDs + resistors)
