Fuel filter keeps leaking.
jkgaddis
So, i was smelling gas everytime i got out of my xj then one day i found my fuel fiter leaking. so i replaced it. easy enough. so that lasted a week. today i found it leaking again. its not leaking at the hoses. its at the seam of the filter. i cant figure out what would cause it to repeatedly leak. i havent been offroading since the swap. i torn down some gravel roads but i cant find any signs of dents or abuse on the filter.
ANY IDEAS?
You must have gotten a defective filter.Or somewhere on the bracket is rubbing thru the filter.I wrapped electrical tape on the clamping side to hold the filter tighter.The hose may go bad too,but that is not your problem now.
Wayne
Concur. Defective filter is the most common cause.
I do, however, keep 1/8" sheet Neoprene in the toolbox, so I can cut new filter strap pads at intervals. Cheap peace of mind, I think... I usually just cover the filter entirely, since that helps to afford some protection, and allows me to move the pad slightly each time (if it's still in usable condition.)
5-90
