xjjeeper19
- inland empire, ca
I have a new dana 44 30 spline factory rubicon air locker. This is the front version open/lock which is stronger than the rear version. It can be used in the rear with no problems, they two are identical other than the internals. It uses a "thick" ring and pinion set that RobertK could set you up with. It comes with a new air actuator, ring gear bolts and carrier bearings. All you would need is a low psi (5 ish psi) air supply to run it.
$600.00 I will ship and I do take paypal
Justin
Justin
