jeepfreak1020
- Thornton
I have 3 short side shafts and 1 long side shaft I wana get ride of.
1st short side - New 760 ujoints ($30)
2nd short side - Bad u-joint ($20)
3rd short side - 290 u-joint but in good shape ($20)
long side - bad u-joint ($20)
And last a HD tie rod I built. 1.5" DOM with .250 wall. Uses heims on both sides. 5/8th bore with a 3/4" shank. Requires you to drill out your driver side knuckle, and drag link. Its a great upgrade, and allows you to run the tie rod OTK on the driver side. Better angles, and more travel with the heims, handles better as well. Will help install as well. ($180) obo
