mini=man
- Neh Hampshuh
High pinion Dana 44 out of a 1977 F150. Has two pairs of knuckles, a pair of spindles, a pair of caliper mounts, and 3 stub shafts. Has carrier and 3.55 gearing but the gears are junk. Guy I bought from welded in between a few teeth for some reason :dunno: I also have a used 4.88 gear for the axle that I'm throwing in if you want. I did not run these gear but I do know they are used. $150
Second is 8 15" white wagon wheels. 4 are 15x8, the other 4 are 15x7. Kinda rusty, so they need to be cleaned and painted before I would put them on anything. $20 for the lot.
All can be picked up in Sandown NH
