- In the islands
which is better, Rusty's tow hooks or the front receiver/tow hitch?
techno1154 said:which is better, Rusty's tow hooks or the front receiver/tow hitch?
BskisXJ said:If you haven't seen this article check it out.
http://www.jeep-tech-tips.com/jeep-tow-hooks.html
Seems like to more pros then cons to using a hitch receiver.
Doesn't look like your loosing any ground clearance either. It's not to much diff in price $$$
No ,you have to ditch the front skid.Hitch bolts on with 6 bolts,it uses the 4 bolts that the sway bar bushings mount with and 1 drilled in the end of each frame rail.StevePSD said:Can you use the Draw-Tite front hitch with the factory front skid or is there interference issues? How/where does the hitch attach to the 'frame rails'?
Thanks.
