The Adam Blaster
- Alberta
Ok, i've got a '98 XJ and i'm trying to replace the stock sway bar links with some JKS quick disconnect ones.
I'm having SERIOUS trouble trying to get the stock lower bolts removed. (These are the ones that run through a small "S"-shaped bracket that is mounted to the axle.) The kit replaces these.
They have Torx heads.
Are these pressed in, welded in, or just threaded in?
I've tried drilling, cutting, and heating up the bracket with a torch and then pounding it with a mini-sledge, but they don't seem to want to come off.
I'm down to a little nub on the driver side, but the pass. side is still intact.
Any help out there for this???
