96country
- Russellville, AR
OK. I just installed control arm drop brackets on the XJ. I pulled the front driveshaft prior to starting the install to check the U-joints and stuff, thinking that it might need to be lengthened. After I finished the drop brackets, I test drove the XJ on the highway and it was nice and smooth. I put the front shaft back in and it seems like it's long enough, but I get pretty bad vibes at anything over 60mph. It had no vibes before the drop bracket install and I added no lift. The pinion angle is even much better now. What do you think it could be?
Here are a couple of pics of pinion angle and the amount of slip in the shaft.
