Micah
- Clarksville, TN
I have done some searching and could not find what I need. I have swapped tires front front to rear and replaced all the bushings in the front end to include the uca bushings on the axle side. the track bar bushings and heim are new this week also. So... whenever I get over 45 or go around a curve at any kind of speed I get a wobble in the drivers tire only. I know this because I stuck my head out the window and can see it but no wobble on pass side. I raised the jeep up and the hub seems tight with no movement at all. I have a ZJ tierod, goferit otk on drivers side, and a durango box (that I hate). I thought it was coming from the box as it has a dead spot but I figured it would be both sides of the jeep. I can hear a noie from the drivers side but its very faint. Should I just replace the hubs and box or do you have any other suggestions?
