ford hp 44 dana 44 front axle 4.56, chromos, 5 on 5.5,
blondejoncherokee
sacramento
high steer arm on pass side for raised drag link
discs, 5 on 5.5.
setup for coilovers
has the ford coil bucket mounts still.
4.56 gearing
EDIT:
i popped the cover. it has a lock right locker.
I need to pop the cover to verify which locker it is.
Chromoly axle thats
it will include the radius arms with that were modified longer and have 1.25 " heims on the frame side.
they are the weld on wedges, not the cast, so if you decide to not run radius arms and want to do your own link setup, then there you go.
i can include the trackbar, you will need to provide your own steering linkage.
starting it at 1900$ OBO.
It has a lock right for the locker.
Just realized the 44 has either CTMs or Yukon super joints in the chromos. surface rust on em so I cant tell exactly, but its one of the two for sure.
Nevermind. One side is chromo with a super joint.
One side is stock with a bad spicer760
SOLD !
