ktm racer 419
- ROW DIALIN
dana44
because its cooler and easier to say when people ask you
flows off the tongue easier
dana44
IMHO, the only difference between a D44 and an 8.8 that really matters is the c-clip thing. Strength wise there's not alot of difference.
We knew what you meant.
I've had an 8.8 in mine on 35s for 3 years and never had an issue out of it. Tho, I did mold a piece of sheet steel to the bottom to make sort of a ramp over the lip. I couldn't imagine dragging that thing everywhere on 31s.
a chain is only as strong as its weakest link
stock 8.8 carriers bring the suck, and ya gotta weld the tubes to the housing.
build it up and the 8.8 is a stout axle. but if you are talkin about building stuff up you can now stuff 33 and 35 spline shafts in a 44. this makes the gearset the weak link, but you can do things like cryro treating, and make sure you get them set up RIGHT and i would rock it.
for one why would you need an 8.8 for 31s, suuuper overkill. and no the 8.8 has quite a few strengths over the 44.
larger ring gear, same size pinion shaft as d60, stronger shafts, stronger housing, and of course the disc brakes are a good bonus
Aww man, so I guess I better swap out my 8.8 for a D35 since I have 31's. But in all honesty, it is a bit overkill, but it was cheaper for me to buy an 8.8 with 4.10's than it was to regear. The clearance (or lack there-of) is noticeable though lol
Oh, and another perk about the 8.8...there are a lot of old school Ford guys around here that will replace bearings and gears in the 8.8. Almost no Jeep support (aside from your typical autoshop chain)
