poorboy_616
- Vancouver, WA
Mine was owned by the forest service, so they may have modified it somewhat. From the outside it looks like a standard 231. Even the tag is correct. 1987 NP231 2.72:1 LR.
You do need to roll them back and forth to verify it's in nuetral though. Just a few feet in each direction does the trick....
ALso I have found Neutral to be very elusive, to far back on the stick and it's 4LO, to far forward and your back in 4HI.
I have E-mailed my friend who helped design these, so he may have some input aw well. It could very well come down to operator error or t-case design. Some may lock other may not.
Mine and my friends Al's both freewheel front and rear drivelines.
If they were locked together as in 4HI or LO you wouldn't be able dolly tow it either! It would try to roll of the dolly as soon as you moved it......
When in doubt, pop the DS off the rear and go that way. No harm done unless your forget to reconnect it.
