langer1 said:
I'd say that won't help at all. It doesn't agree with the real world.
A 1990 is a Renix, the same as an '88. I just went out and checked both my '88 XJ and my '88 MJ. They are almost exactly the same. Here's how they shape up:
Viewed as standing at the right front wheel and looking across the distributor toward the engine, #1 is at lower right, about 5 o'clock. #5 is at lower left, approximately 7 o'clock. (On the MJ a line through #1 and #5 is EXACTLY parallel to the block. On the XJ the distributor body is "clocked" very slightly counter-clockwise compared to the MJ, so #1 might be at like 4:45 rather than 5:00 o'clock).
On both, the wire for the camshaft pickup is located between #1 and #5, and the cap screw is located between #5 and #3.
This is not even remotely close to the illustration. Both of these vehicles run well. The XJ has been this way for 250,000 miles and gets over 20 MPG. The MJ was bought used, the distributor hasn't been touched since I bought it, and it gets 19 to 20 MPG on the highway with the tailgate up.
I think it's safe to use this as a guide to setting yours up.
