I'm currently working on a build plan for my stroker motor. I will be trying to put together a very complete parts list for this stroker build. I will be making changes from your inputs and after more researching. So, I'll update the parts list until its satisfactory. I want to include parts with prices, machine work needed done with approx cost. I want to hear input from you about which parts/brand to use, cost of work.. and any additional ideas to my build.
The build: 89 XJ 4.0 motor with Renix system. Turning into a 4.6 stroker motor.
*Parts list*
Block: Stock 89 Renix 4.0 block casting number: 53005535
- bore over .030
- No decking
- no balancing
- dip
- new cam bearings
- new frost plugs
- cost of machine work ?
Crankshaft: Stock 4.2 remanufacture casting number: 3214723 $190(with bearings from Schucks.com)
- 12 counterweights, 66lb, 64mm nose
- custom 10mm spacer
Connecting rods: Stock 4.2 part number: 3180444 Casting number: 707
- New rods $35 each($210.. better deal out there?)
- still need to have them resized ?
Pistons: .030 oversize
- Type ?
- press on rods $?
Camshaft: Stock HO used
- Possible a/m if good one found
Clyinder head: HO head casting number: 7120
- Regrind valves seats/valves
- Mill guides if needed
- $0(doing that myself)
Intake manifold: Stock HO
-Throttle body adapter for renix $?
Exhaust:
- APN header
- Custom downpipe with flex line
- 2.5” tube
- Large quiet muffler
- need to search on prices
Need to figure out:
- Type of pistons
- Head gasket type/size
- Approx cost of machine work
Additional parts needed:
- Lifters
- Gaskets
- Rings
- Bearings
- Water pump
- Timing gear set
- motor mounts
- What else should do with the motor out ?
- ford racing fuel injectors 19lb(already have set)$0
So with my parts list, you can see that I'm building a fairly stock motor with an improved exhaust. What I want is a good DD motor that runs on regular gas.
*Parts list*
- bore over .030
- No decking
- no balancing
- dip
- new cam bearings
- new frost plugs
- Type ?
- press on rods $?
Exhaust:
- APN header
- 2.5” tube
Need to figure out:
- Type of pistons
- Lifters
- Gaskets
- Rings
- Bearings
- Water pump
- Timing gear set
- motor mounts
