blazinjames
- Vancouver BC, Canada
so I finally have pieced together my lift but im not sure if I want to just lift it 3inches of 5in
I have 3in procomp coils
stock leafs with pro comp 3in add-a-leaf
I have upper and lower adjustable control arms rubicon express
I aslo have a set of procomp fixed lower control arms(dont plan on using)
I have a transfercase with sye installed and was planning on using a XJ front drive shaft(might not install if only lift 3in)
i have procomp shocks that came with the lift
I figure since I have the control arms and the SYE i could lift the jeep another two inches with 2in coil spacers and 2in shackles
Will i need a drop pitman arm if i got 5inches? what issues will I have with stock steering setup
and will I need to extend the front brake lines or can I just relocate?
is there anything I am missing?
