hupo224
- Manchester, NJ
Got a small yellow multimeter with the 2 probes. It has an ohms adjuster wheel and it has. off x10 x100 x1k(ohm) 500 250 50 10 (acv) 250 10 0.5 (dcma) 2.5 10 50 250 500 (dcv)
Should I carefully move the unit under my jeep. plug it in, connect my negative battery terminal then try and test it?
Also there is no rubber seal. There is the lock ring and that is it. The lock ring is a bit rusty and the top of the fuel pump is rusty. Where the ground is on it looks bad. Not sure if it is grounding properly. Still waiting on an answer about plugging it in.
