- Rainy side of Washington
Sounds a lot like the center pin or a c-clip issue, yeah. I'd bet that the bearings are riding on a crappy section of the shaft when the shaft slides the wrong way, and howling. Luckily a new center pin will cost you a whopping $10 at the JY most likely, and the retention bolts are $6 for a bag of 3 at the dealer, if you end up needing one. Make sure you use a 5/16" 6 point wrench (not a socket, too much off-axis torque unless you're way better than I am) on the retention bolt, NOT an 8mm or a 12 point of any sort!
(don't ask!)
(don't ask!)
