nrwphoto
- Appleton, WI
Alright 2 yrs ago I replaced my radiator along with all cooling components. Since then I have replaced the fan clutch 2 additional times. Even when it is 115 outside and the engine is running at 235 I don't hear the fan clutch kicking in. I have had a couple of Chevy blazers that when the fan clutch locked up you could hear the fan roaring. Not so with this 4.0 XJ. I tried going with a heavy duty clutch from both Autozone and Checker, but neither would fit on the stock fan. The clutch diameter was larger than the inner diameter of the fan causing it to rest against the blades about 1/4" from bolting up tight. Are all of your fans quiet as well or do you think I should try another clutch and or fan. I was thinking about an electric conv. but think I want to stay away from the grief at this time. Thanks
