94xjstud
- San Jose Ca
I went to get my jeep smog and it failed. The guy say that it failed becuase the engine appeared to be being over worked. He was not sure of the problem but said it could be a clogged cat, bad O2 sensor, intake leak or something else. Not sure what that means but here is what I have.
94 xj, straight six, intake routed through the cowl, magna flow 40 series exhaust (about 3 years old), 5" lift, D30 - 4.56 gears and aussie locker, D44 4.56 gears and aussie locker and 33" tires.
Before the smog, I recently did an oil change, transmission fluid flush, new oil pressure switch and changed the valve cover gasket. Since I did the value cover gasket and oil change, my oil pressure gauge was been consistantly at about 60.
Any ideas? I want to do as much as possible on my own because I am on the unemployment budget
