- Rainy side of Washington
1) yes, the OSS signal is completely different as well. This is covered by the first post, let me know if anything isn't clear.
2) should be the same, swap yours over. Dump some atf around where the tube goes into the other tube and spin it back and forth and it should get easier to remove. Replace the o-ring.
3) sadly, probably not, the yota trans will have a giubo joint or a metric ujoint and companion flange of some sort most likely while the jeep one uses a 1310 size ujoint. The yota may not have the same seal diameter or spline, either. And I believe your driveshaft length will be different 94 vs 96 jeep as well. Your slip yoke should work with the newer trans but the driveshaft length will almost certainly be several inches off.
I would have to check the parts catalog to be certain but I am pretty sure you would be far better off either getting the donor's driveshaft (assuming it has the same rear diff as yours) or getting the right year range transmission. 95 and down would be a good start but I am not 100% on that, I have never seen a 2wd auto XJ up here, only 2wd poverty spec manuals.
