Gearing wise, being around 10% lower than stock helps to handle the larger tires. I must admit though, it was a tough choice for me. 4.11 gears would have been the break even "back to stock" choice and, of course, 4.88 gears would have been the better Off Road choice. Given the two factors of Forced Induction (pull power? and the fact that I am loath to run a pinion gear that small, the 4.56 set made sense.
Meanwhile, back at the Ranch...
I agree that short of putting a scope on the signals, we will have no idea of what they are. Good news is that that can be done in the garage. Jack Stands are such a wonderful invention. A speed sensor signal voltage reading would be delightful indeed.
Kastein, if you locate the programmer adapter, let me know and I will chip in on the purchase price. Only fair after all.
I thought it would be appropriate, at this juncture, to post up a system level drawing for the TCM. This is copied out of my Diagnostic Manual.
[/URL][/IMG]
As can be seen here, the TPS is monitored and the Speed Sensors are documented as to tooth counts. Determining the count could be an easy task but, I feel that is is not required. If the thought is that we can lie to the TCM about the actual speed of the transmission, then all that would be required would be to massage the signals.
The AEM F/IC8 that I run does the exact same thing with both the Crankshaft and the Camshaft Position Sensors. By digitally delaying those signals, the ignition is retarded under boost. As both signals are offset by the same amount, no error codes are generated.
My concerns here are:
1) Speed Sensor voltage levels.
2) Interplay of the TPS.
IMO, as soon as we can determine the TPS involvement, we will be home free. As I see it, this is the impediment. Offsetting the speed sensors would not be that difficult. These parts may fit the bill. The choice could be made via a simple switch for the new circuit to be active or no. Sort of a Street/Trail selector switch.
Frequency to voltage converters, Texas Instruments LM2907 and LM2917
Voltage to frequency converter, Texas Instruments LM231N/NOPB
It has been a very long time since I attempted any sort of new design so am open to meaningful suggestions...
