jimbosz07
- San Carlos/Redwood City
When you welded them on did you disconnect the LCA from the axle?
Remove them so you can weld the inside of the stock control arm brackets to the axle tube, before welding on the mini-skids.
Or you could not, and get some kid to freak out while he watches you drive your first trail at Johnson Valley! Right Bryan? :eeks1:
Alright I will definitely be disconnecting the arms and running beads on the inside too then. Thanks for all the answers
By the way, you can avoid actually buying the skids from JKS or something for a lot of money if you just get some 3x3 chunks of steel and weld them in. My local steel yard didn't even charge me for them
I've always straightened LCA brackets with a pair of vice grips... still gotta pull the LCA out though.I'll have to remove my LCAs just to beat the curled-up mounts flat enough to weld on the skids. Plus, I've already got torn control arm bushings from the last six months of wheeling, so I might as well swap out the bushings while I have the arms removed. Mini-skids are a good stocking stuffer for Christmas, right?
How do you guys clean the rust (well, paint, I guess, in your neck of the woods) off the axle tube and inside of the LCA bracket before welding it? I can't get my grinder in there, nor a wire brush really, always figured I'd use a die grinder bit or a mini wire wheel on a dremel.
