- MilkyWay Galaxy
87 Renix rig, 292,000 miles.
I have had worn valve guides and oil consumption and fouled plugs I worked around for 70,000 miles that have gotten worse, and stick lifters that stop sticking if I ran the RPMs up in cold morning starts to unstick them, and when the #1 and #2 plugs would foul I would get miss like I have now that was always fixed with new plugs or by cleaning the old plugs of the oil fouling.
But now the problem is different, and the miss when I accelerate past 2000 rpm (varies, when hot it will go to higher rpms with out the miss, some times) not only misses but back fires out the exhaust. Pop pop pop sounds and power stalls and rpm stops rising as you give it gas.
I ran the MT-2500 Snap on sensor tests, ran a vacuum gauge test, ran the fuel pressure tests, Sensors are all good and working, TPS is 3 months old Mopar, CPS is firing like a demon, and I ran the compression test and my worst two cylinders are actually better after using Restore for 4 years and the NGK FR5 plugs and fixing the fuel injector issue...and the idle is perfect
But the compression test does not tell me if a valve is misaligned and not seating under acceleration or at higher pms, as it does at cranking speed.
I also used a 25 year old Matco engine systems analyzer I scored on Ebay 10 years ago that gave me Ms rise times and peak and average HV firing data that indicates that the spark, and power contribution per cylinder all seems to be OK, even excellent as well. Getting close to 17 mpg pure highway at 60 mph, O2 sensor is 12 weeks old working perfectly.
None of these tools gave me any clues to what is causing the miss-back fire even when I watched them while I made it back fire and idle badly for 10 seconds, they all indicated no problems, but when the problem happens I can not accelerate in park to higher RPMs with out it back firing and shaking.
IF I let her idle for 20 minutes (get warmed up), or just sit for 2-3 days, or wait for a full moon the problem is not as bad, sometimes, and one day it may just refuse to go over 2000 rpm in park before it shakes violently, the next day it can reach 4000 rpm for a bit, and in between.
The rapid acceleration miss showed up at first for a few seconds on cold morning starts but would go away 100% if ran it at 4000 for about 10-30 seconds, then no problems all day. A slow climb in rpms is less likely to trigger the miss, but on other recent tests it just bogs down at 2000 to 2200 rpm and refuses to go higher, day later I warm it up 20 minutes then I managed to get to 4000 rpm for a 10 second stretch, before it barks at me
5 days ago the problem decided to stay for good, till today. Today it was still there, but not near as bad. Bad enough though that I have parked it.
I do plan to pull the valve cover next.
Looking for ideas on what I might have missed.
Coolant and oil are normal. No over heating. Tests and problems are in park!!!!!
The vacuum gauge showed no compression or valve issues at all even when I made it miss-backfire, which kinda stumps me.
Fuel pressure was stable during the miss.
Plugs 1 and 2 were replaced, made no difference. Dizzy rotor and cap have only 2000 miles on them and are fine. No vacuum leaks, idles like a champ!!!!
I plan to reconnect the new Knock sensor and see if anything changes next. I doubt it will, but worth a try as I did hearing some pinging on acceleration off and on the last 2-3 months if I tried to push her in low gear too hard.
This feels mechanical like valves/valve-lifter train on the edge of going bad, but I am no expert on those in failure mode.
Oh, EGR passed the tests, not the problem. Plugs and wires all great, not much age on them.
I'd suspect the ICM-HV coil if not for having run the Matco analyzer tests and them indicating no spark problem during the steady misfires.
