Onkover
- Red Bluff CA.
First I would like to say that i have searched and can't find what information I need
I have a check engine light with the code #27 being thrown. Code 27 has two parts. 1. Injector control Circuit--bank output driver stage does not respond properly to the control signal 2. Injector No. 1,2 or 3 control circuit and peak current not reached.
This is causing sporadic rough idle and sporadic running rough under light throttle. IT smooths out when I stomp the pedal but laws forbid me to dive like that all the time.
I need some help here. I have taken a ohm meter to the 1, 2 and 3 injectors and all read the same... open circuit. What is causing this and what can I do to get rid of this problem?
