bigalpha
Moderator
- Tucson, AZ
After you guys figure this out can you please respond to my post
EMERGENCY OMFGIMGONNADIE : dome light out.
Thanks in advance
:thumbup:
Thanks in advance
i have know clue what reostat is or where that is need some help with that one.
Thanks in advance
I would suggest, based on this and your previous threads, to take the jeep to a shop and have them fix it, and watch if they'll let you.
Sincity- did you ever replace(or even troubleshoot) the headlight switch when it was malfunctioning a few weeks ago? Guess what other lights it controls... Checked your battery lately, alternator output, cable connections, grounds, bulbs, fuses, etc etc? You seem to have a new electrical malfunction every time you touch it- some preventative maintenance is probably called for here...
Two words......LED FLASHLIGHT! Seriously dude. its not hard to figure out!
Replace with Toyota, Honda, or VW = problem solved!
yep. a slammed rice burner tuner would suite you nicely
Did you ever try rotating the headlight switch to see if it's in the right position to make the dash lights come on? The rheostat thing?
