My 2001 xj has several issues that may or may not be related. First, when I hit the brakes my odometer light goes out. Also when braking the front turn signal lights come on (solid not blinking). The blinkers work but when the headlights are on the right rear flashes quickly and blinks but is dim and the entire light housing seems to be lighting up and blinking together. Weird stuff. I already replaced the bulbs but no luck. Am I looking at a relay, flasher, switch or possibly a ground issue? I'm hoping someone can give me a good starting point. Thanks in advance!
