I recently found the fan on a Ford Contour(3.0 V6) was thin enough to fit between my water pump and radiator. I grabbed it and put it in.
The fan itself is made to be a puller fan, but that didnt seem to work too great for me. What do you suppose I should use it as? A puller or a pusher?
However I've tried both ways and my motor runs a lot hotter with this fan than a clutch fan that didnt clutch. Maybe I'm missing something? When the fan is on you can feel the air about a foot away from the truck(going through the rad) so I have no doubt it blows enough...
Any input appreciated, thanks!
