90xj06
- Peabody, MA
i have a 90 that i swapped the engine into an 88. i used the injectors and tps from the 88's original motor. and it seems like it doesn't have as much umph as it did before i swapped it.
assuming that the injectors and tps are working as it should. could the ecu be the difference?
ill probably swap it over anyhow but im just curious.
