Bradzuki
- McMinnville, TN
Since I'm replacing the oil pump in my '87, I figured I'd go ahead & swap out the main & rod bearings. I ordered up a set and got started tearing down this morning. I got the main cap off & noticed that the bearing in it is labeled .010, the ones I got are standard size.
I pulled a rod cap off & it has a bunch of numbers on it but nothing that comprehends to .010.
Question is this. Is it safe to assume that since the mains are oversized, the rods are the same size? I have already re-ordered the bearings but wanted to make sure first. The engine is still in the jeep, just the oil pan is off.
Thanx,
Brad.
Thanx,
Brad.
